ACWWong
eng, you can do what you want in both wavescan or awv in Cadence:
in wavescan: having moved the two curves you want into a window, select one of them, then Trace->Assign to Axis->New Axis. Haveing done this any subsequent waveforms added to that window can be assign to either a new or existing y axis in the same way.
in awv simply double click the curve and in the dialog box which pops up you can change the Assign to Y axis setting
cheers aw
