Jul 20th, 2024, 9:17pm
How to supeimpose 2 plots in Cadence Waveform (Read 4059 times)
eng
USA
Apr 17th, 2007, 1:04pm
Hi
I have 2 curves (dominant pole, phase margin) generated in Cadence Waveform after an AC anaylsis. They have different Y-Axis scales. I'd like to superimpose these 2 curves in a plot such that one uses right Y-Axis, the other one uses left Y-Axis. (I'm dragging them from different subwindows to a new subwindow the arragement should be done after that)
Could anyone tell me how to do that?
Re: How to supeimpose 2 plots in Cadence Waveform
Reply #1 - Apr 17th, 2007, 9:09pm
Hi, eng,
If the two variables have the same x-axis, of course they can be plotted in one window.
Yawei
Reply #2 - Apr 18th, 2007, 3:50am
Yawei -
I know I've done "append" to put a second curve on with a first, when they share an X axis, but I think by default they share the Y axis as well.  eng wanted to assign one curve to use the right edge of the plot for its Y axis.  Is there an options menu to set this up?
ACWWong
Oxford, UK
Reply #3 - Apr 18th, 2007, 4:40am
eng,
you can do what you want in both wavescan or awv in Cadence:
in wavescan:
having moved the two curves you want into a window, select one of them, then Trace->Assign to Axis->New Axis.
Haveing done this any subsequent waveforms added to that window can be assign to either a new or existing y axis in the same way.
in awv
simply double click the curve and in the dialog box which pops up you can change the Assign to Y axis setting
cheers
aw
