Mar 2nd, 2026, 2:45pm
trise/tfall in transition filter problem (Read 5750 times)
morozmoroz
I need everything be
in behavior:)
Ukraine, Kiev, Melexis
Apr 18th, 2007, 2:57am
Hi, everyone.
I have now a little problem, concerning mixed signal simulation.
I can not set rise and fall time for transition function for modules written in VerilogAMS less than 2ns. I have warning in SimVision console:
"../INV/verilogams/verilog.vams"
      18: instance (INV+verilogams+0x10000001
      behavioral) 3 of INV+verilogams+0x10000001:
      Value specified for rise or fall time (1 ns) for transition filter is
      too small.  Value set to 2 ns.
      This message will not be repeated for this filter.
How can I overcome this problem?
Look to the Root - The Flower of the Life if there Smiley
View Profile 304377506   IP Logged
Re: trise/tfall in transition filter problem
Reply #1 - Apr 18th, 2007, 3:52am
Do you have a default timestep/timescale for the digital blocks?  Probably the analog section can't be too much smaller than that.
morozmoroz
in behavior:)
Reply #2 - Apr 18th, 2007, 4:08am
Geoffrey_Coram wrote on Apr 18th, 2007, 3:52am:
No, I haven't.
Additional: I use UltraSim. This schematic isn't big, just 4 simple units. They are written in VerilogAMS and Verilog.
Could it be that my ncsim is very old and this couses problems? Our IT now are updating UltraSim to the IUS5.8
s004 version, may be it will help.
Fill free to suggest.
Thanks in advance!
morozmoroz
in behavior:)
Reply #3 - Apr 18th, 2007, 5:01am
Huh, I have solved the problem.
The root is in transient simulation time. I have used Cadence SourceLink and found:
The minimum rise or fall time for a transition filter in a transient
simulation is given by:
 Tstop - Tstart / 500e6
I have used 1 sec and got 2ns minimum rise time.
Conclusion - using the SorceLink is very useful:)
Reply #4 - Apr 19th, 2007, 3:32am
BTW, there is a parameter transres which can be used to relax this requirement (don't push it too far though):
27	transres=1e-9*stop s
				  Transition resolution. The transient analysis attempts to stop at corners of
				  input waveforms. (ex. corners of rising/falling edge of a pulse). If such
				  events occur within a time less than transres, the analysis will combine the
				  events into one and force only one time point. The rest of the steps will be
				  determined by error control. This may lead to loss of detail.
The above is from the spectre help on tran, but it can also be used with AMS.
You need to be careful if you tighten this that you don't run out of numerical headroom on the timestep resolution - with sufficient accuracy to follow the transition.
