Aug 14th, 2024, 10:15am
Mixed signal IC manufacturing cost (Read 2544 times)
mg777
Apr 18th, 2007, 9:29pm
I need to understand the IC manufacturing cost structure for a mixed-signal ASIC, details below.
(i) RF in the 50-250 MHz range
(ii) ADC-DAC 12 bit @ 1 MSPS
(iii) 100K digital gates + 16 KB SRAM
(iv) 50 MHz clock freq
(v) 32K of Flash (or E2PROM)
(vi) ESD & I/O cells
(vii) 16 pin TSSOP or QFN, wirebond
(viii) Volume 1M up per quarter
The cost includes a production mask set, X mm wafer fab, packaging, & ATE (Iddq/Pin + scan + analog verif). Royalties for digital physical blocks need not be included here. The goal is to choose an optimal technology node - say between 90 nm, 130 nm, & 0.18 um.
I keep hearing a wafer fab cost of 10 cents per mm2 for 130 nm - is this correct, and will it be less for 0.18? Any answers or references appreciated.
M.G.Rajan
