If I remember rightly, you do need the symbols. That said, it's not exactly onerous to create the symbols, since they can be generated automatically from the verilog-a code.
But I may be wrong - I've not checked this recently, nor done any searches to see what the current status is (so why am I answering?).
Anyway, I wanted to make sure that you were using the automatic symbol generation (which it would ask you to do when you created the verilog-a views), and if not, why not?
