Jul 18th, 2024, 10:29am
Simulation of cells with VerilogA view (Read 2870 times)
rajdeep
UK
Apr 18th, 2007, 11:57pm
Say, I have a top module named TOP. It uses three submodules A1,A2 and A3. All these modules have only no veriloga view.
They do not have symbol or schematic view. I only create a Symbol of the top module TOP.
I instantiate this TOP in a design schematic and try to run the whole system. But it fails to complete the step of netlisting
When I create symbols of the submodules A1, A2 and A3 it works fine.
Why do I need the symbol view of these A1, A2 and A3? In the hierarchy editor I use only their veriloga view. I had to create the symbol view
of the top module TOP because I had to instantiate it into another design schematic.
Is there a way out? or I have to create the symbols?
Plz help!
Rajdeep
Re: Simulation of cells with VerilogA view
Reply #1 - Apr 19th, 2007, 3:28am
If I remember rightly, you do need the symbols. That said, it's not exactly onerous to create the symbols, since they can be generated automatically from the verilog-a code.
But I may be wrong - I've not checked this recently, nor done any searches to see what the current status is (so why am I answering?).
Anyway, I wanted to make sure that you were using the automatic symbol generation (which it would ask you to do when you created the verilog-a views), and if not, why not?
rajdeep
UK
Reply #2 - Apr 19th, 2007, 5:01am
Hi Andrew,
I've posted a reply message to one of my own queries (!!) how to generate a symbol from verilogA view.
http://www.designers-guide.org/Forum/YaBB.pl?num=1176965163
Very much, the same command you suggested.
So, currently I'm not too much worried about not having symbol view of submodules, which are in verilogA .
Thanks a lot Andrew!!
Rajdeep
