Jul 21st, 2024, 5:11am
How to calculate k'=u*cox value in mos? (Read 9188 times)
hande.vinayak
BOM
Apr 19th, 2007, 7:50am
Hi to all,
  Can anybody tell me, how to calculate k'=u*cox value in mos?
  I am using TSMC 90 nm PDK.I am working on cadence spectre for simulation.
  Plz,do the needful.
  Thnx,
« Last Edit: Apr 19th, 2007, 9:38pm by hande.vinayak »
Re: How to calculate k'=u*cox value in mos?
Reply #1 - Apr 20th, 2007, 7:14am
Hi, hande,
I have tried to simulate the I/V curve and extract the K' value. It is impossible to calculate K' value from the model parameter because of the complexity of notorious BSIM3 model.
Yawei
Mobeedikk
Reply #2 - Apr 20th, 2007, 9:00am
What I usually do is get a representative W/L of the type of transistor I'd use, then
extract Vth by:
1. plotting Ids vs Vgs with Vds at some small voltage (~50mV is typical).
2. take the derivative of this to get gm
3. find the Vgs that corresponds to the maximum gm
4. linearize the Ids vs Vgs curve around this Vgs point, and extrapolate back to the x axis. This will give you Vth
I then plot out an Ids vs Vds curve, and do a least squares fit of the equations to the IV curve to find k'. If you're using square law, fit the square law equation to the IV curve. If you're using Rabaey's velocity saturation equation, fit that equation to the IV curve.
Reply #3 - Apr 23rd, 2007, 4:17am
Hmm .. I thought there was a "ueff" output parameter, but I don't see it.  There is a betaeff in Spectre, which ought to be ueff * Cox * Weff / Leff.  Can you use that?
