Jul 21st, 2024, 7:19am
How to plot Op Param of FET with swept DC analysis (Read 2334 times)
eng
USA
Apr 24th, 2007, 9:27am
I'm using a FET in triode and I'd like to plot its Rds vs. Vgs for different Ws. To do that;
I'm sweeping Vgs in DC analysis and changing Ws with parametric analysis tool. The output is the Rds with the expression of "(1/OP("/M1" "gds")
However this setup does not give me multiple Rds versus Vgs curves for different W sizes as expected.
My guess is; in order to plot the Rds, I should do a setting so that simulator saves the op point of the FET during DC sweep. I don't know how/where I can do that.
Could you please help me with that?
thanks
eng
Re: How to plot Op Param of FET with swept DC anal
Reply #1 - Apr 25th, 2007, 3:41am
A cheesy work-around would be to place multiple devices, if you don't have too many W values you want to test.
topquark
Thames Valley, UK
Reply #2 - Apr 26th, 2007, 3:04am
Hi eng,
If you're familiar with MDL, you can do this conveniently with two nested foreach loops
alias measurement Rds_vs_Vgs{
run dc (...)
export real Rds=(1/(M5:gds))
// To get Rds of the device
foreach Vgs from swp(start=.., stop=.., step=..) {
		  foreach W from swp(start=.., stop=.., step=..) {
run Rds_vs_Vgs
Check out the forum posts on MDL for some idea on this.
Good Luck!
Gau
