Aug 15th, 2024, 12:43pm
How to break in a "case ...endcase" statement ?? (Read 5157 times)
ZaraCattle
Apr 20th, 2007, 4:26pm
I'm using "always" block.In this block I use "begin ...and   " and 2 "case ...endcase"..I don't know how to my program only can excute one of  2 "case ...endcase" everytime I excute this block....I mean when I excute a above "case...endcase",then it still excutes a under "case...endcase"...Please help me.....Thanks everybody very much...
Saran
Getting wiser by the
second
Re: How to break in a "case ...endcase" statement
Reply #1 - Apr 25th, 2007, 8:15am
Please spell out this problem more clearly...Thanks!
Reply #2 - Apr 25th, 2007, 10:49am
You probably want:
case (var)
  1 :  $display(" got a 1");
  2 : begin
	$display (" got a 2");
	var = 1;
  default $strobe("got something else");
endcase
I think you probably mis-understood the syntax for case/endcase.
ZaraCattle
Reply #3 - Apr 27th, 2007, 1:32am
This is my code
`timescale 1 ns / 1 ps
module IC74LS160 (Pin_Pe,Pin_P0,Pin_P1,Pin_P2,Pin_P3,Pin_Cep,Pin_Cet,Pin_Reset,Pin_Q0,Pin_Q1,Pin_Q2,Pin_Q3,Pin_Tc,Pin_Clk);
input Pin_Pe,Pin_Cep,Pin_Cet,Pin_Reset,Pin_P0,Pin_P1,Pin_P2,Pin_P3,Pin_Clk;
output Pin_Q0,Pin_Q1,Pin_Q2,Pin_Q3,Pin_Tc;
reg Pin_Q0,Pin_Q1,Pin_Q2,Pin_Q3;
reg [3:0]dem;
initial
   dem = 0;
always @(posedge Pin_Clk)
begin
    casex ({Pin_Reset,Pin_Pe,Pin_Cet,Pin_Cep})
	//Neu Chan Reset khong tich cuc va chan PE tich cuc thi load cac gia tri hien tai cua chan Pi vao chan Qi
   4'b10xx:
	begin
	  Pin_Q0 = Pin_P0;
	Pin_Q1 = Pin_P1;
	Pin_Q2 = Pin_P2;
	Pin_Q3 = Pin_P3;
	  dem[0] = Pin_Q0;
	  dem[1] = Pin_Q1;
	  dem[2] = Pin_Q2;
	  dem[3] = Pin_Q3;
//Neu Binh thuong thi dem binh thuong
4'b1111:
begin
if (dem <9)
	begin
     dem = dem + 1;
     Pin_Q0 = dem[0];
     Pin_Q1 = dem[1];
     Pin_Q2 = dem[2];
     Pin_Q3 = dem[3];
	//Neu Chan Reset tich cuc
	4'b0xxx:
	begin
	 dem = 0;
	Pin_Q0 = 1'b0;
	Pin_Q1 = 1'b0;
	Pin_Q2 = 1'b0;
	Pin_Q3 = 1'b0;
endcase
//I don't want to excute second "case ...endcase " statement
//when the program excuted first "case ...endcase" statement
//I want the program will exit out of "Always" block
//when the program excuted first "case...endcase" statement
case({Pin_Q0,Pin_Q1,Pin_Q2,Pin_Q3})
	//Neu Dem den 9 thi tro ve 0 trong xung ke
	   4'b1001:
	   begin
	     dem = 0;
	   Pin_Q0 = 1'b0;
     	 Pin_Q1 = 1'b0;
     	 Pin_Q2 = 1'b0;
	   Pin_Q3 = 1'b0;
//Neu ban dau o 11 thi tro ve 6 trong xung ke
	 4'b1101:
	 begin
     	 dem = 6;
		 Pin_Q0 = 1'b0;
		 Pin_Q1 = 1'b1;
		 Pin_Q2 = 1'b1;
		 Pin_Q0 = 1'b0;
//Neu ban dau o 13 thi tro ve 4 trong xung ke
	 4'b1011:
	 begin
	   dem = 4;
	   Pin_Q0 = 1'b0;
	   Pin_Q1 = 1'b0;
	   Pin_Q2 = 1'b1;
	   Pin_Q3 = 1'b0;
//Neu bat dau o 15 thi tro ve 2 trong xung ke
	 4'b1111:
	 begin
	   dem = 2;
	   Pin_Q0 = 1'b0;
	   Pin_Q1 = 1'b1;
	   Pin_Q2 = 1'b0;
	   Pin_Q3 = 1'b0;
//Neu ban dau o 10 thi nhay len 11 trong xung ke
	 4'b0101:
	     begin
	   Pin_Q0 = 1'b1;
	   Pin_Q1 = 1'b1;
	   Pin_Q2 = 1'b0;
	   Pin_Q3 = 1'b1;
//Neu ban dau la 12 thi nhay len 13 trong xung ke
	 4'b0011:
	 begin
	   Pin_Q0 = 1'b1;
	   Pin_Q1 = 1'b0;
	   Pin_Q2 = 1'b1;
	   Pin_Q3 = 1'b1;
//Neu ban dau la 14 thi nhay len 15 trong xung ke
   	   4'b0111:
	 begin
	   Pin_Q0 = 1'b1;
	   Pin_Q1 = 1'b1;
	   Pin_Q2 = 1'b1;
	   Pin_Q3 = 1'b1;
endcase
Thanks for your helping....
Reply #4 - Apr 27th, 2007, 3:52am
You could do something like:
integer done;
begin
  done = 0;
    4'b10xx:
	begin
	  done = 1
  if (done == 0) begin
ZaraCattle
Reply #5 - Apr 27th, 2007, 7:47am
Thanks you Geoffrey-Coram.. I thought this way to solve my problem...I only want to know another way that is easier to solve my problem...It's like "break" or "exit" in C..Thanks for your ideas....
Reply #6 - Apr 30th, 2007, 4:21am
It's not like break in C, because there's no enclosing loop to "break" out of, and even if there were, the "break" would apply to the case statement (the innermost construct).  In a very contorted way, it might be like "continue" if you considered the simulator's timestep control loop as the enclosing loop (while time < end_time) or "return" if you considered the module execution as some sort of function.
