Oct 18th, 2024, 12:41pm
PLL divider ratio (Read 3121 times)
chase.ng
penang/malaysia
PLL divider ratio
Apr 22nd, 2007, 2:00am
I notice that most motherboards are having 14.318 MHz, anyone has idea what is the divider ratio to generate the system clock at 133 MHz/200 MHz?
thanks and regards,
chase
Chase
View Profile chase.ng   IP Logged
mg777
Re: PLL divider ratio
Reply #1 - Apr 22nd, 2007, 12:16pm
The 14.318181... MHz is some multiple of the color subcarrier in TV's, and dates to when early computers used TV's as monitors.
To answer your question, 100 = 14.31818181... * 440/63
In practice there will be a ppm spec on the crystal, and a steady-state error in the PLL.
adesign
Reply #2 - Apr 25th, 2007, 9:47pm
It also depends on the maximum divider settings allowed on motherboard.
