Jul 16th, 2024, 8:38am
LVS problems (Read 2352 times)
Kudie
LVS problems
Apr 23rd, 2007, 12:26pm
I'm trying to create a mixed signal layout with two different supply lines for the analog and digital part. I have great problems to get the schematic and the layout matching in the LVS. It looks like that Assura (and Calibre) have problems to match the two supplies. I get messages like "standard cells not connected to gnd!", even when they are connected to vss_d and vdd_d. I have tried to map gnd! to vss_d by an inherited connection (in the schematic), but thats not enough for LVS...
Can anyone give me a hint how to solve this problem?
Thank you very much!
Markus
didac
There's a million
ways to see the
things in life
manresa,spain
Re: LVS problems
Reply #1 - Apr 23rd, 2007, 11:12pm
sometimes I found strange errors like this in Assura. It seems like it depends on the PDK. As far as I know usually is a problem related to the labels names, try to change the names to things like GNDA,GNDD without "_".
Good luck.
