Jul 21st, 2024, 12:16am
Measuring RX IMR (Read 3360 times)
uncle_ezra
Measuring RX IMR
Apr 25th, 2007, 10:40pm
How do you measure RX IMR? Do we input two tones and measure the wanted and image signal in the baseband?
uncle_ezra
Re: Measuring RX IMR
Reply #1 - Apr 26th, 2007, 2:19am
I guess you just need to input a single tone and if there is I/Q imbalance in your receiver you will see the image appear at the output. How do you determine the frequency at which the image will appear?
ACWWong
Oxford, UK
Reply #2 - Apr 26th, 2007, 2:50am
you need to input just one signal at the image frequency at the RF input, which causes an in-band response in your receiver. The ratio of this image stimulated in-band response versus a wanted input signal response gives you the image rejection.
The input RF image frequency depends on your architecture... for a super-het, it is offset from the LO by the IF (opposite side to the wanted frequency).
