Aug 17th, 2024, 1:17am
Turn off flicker noise for pnoise-analysis (Read 3259 times)
Berti
Apr 27th, 2007, 6:13am
Does somebody know how to turn off the flicker noise for
a pnoise-analysis (and to simulate white noise only)?
Re: Turn off flicker noise for pnoise-analysis
Reply #1 - May 1st, 2007, 10:31pm
You could remove the parameters in the device models which define the flicker noise.
Why do you want to do this? You can always see the noise contributions of each type of noise source after the simulation.
Berti
Reply #2 - May 2nd, 2007, 12:02am
When using the pnoise
analysis for simulating jitter/phase noise I can't display
how the phase noise would look like without flicker noise.(??)
But I agree with you that the noise summary shows
the indivual noise contributers. I will probably be content
with that, rather than modifying the transistor model
files.
rfsimer
Reply #3 - May 4th, 2007, 12:30am
my experience showed the reliable way is still turn off it in model file. for example in bsim3 model, assign noimod=1 and kf=0.
