Jul 21st, 2024, 11:17am
Spectre DC accuracy (Read 2697 times)
Visjnoe
Spectre DC accuracy
Apr 27th, 2007, 7:06am
Dear all,
I'm observing really strong results when using Spectre dc analysis (operating point) on some small set of circuits. The problem resides in an LDO in power down, where there seems to flow some current both Kirchoff does not hold on a certain node.
Are there any special accuracy settings I should be looking at to improve the DC operating point calculation?
Peter
Re: Spectre DC accuracy
Reply #1 - Apr 29th, 2007, 2:23am
Hi, Peter,
Sure you can improve the accuracy for the DC operating point calculation like other SPICE-like simulator. Choose simulation->options->analog if you use Virtuoso Analog Design Environment. You could set reltol or iabstol there, and any other options in the blank at the bottom of the poped window.
Best regards,
Yawei
Reply #2 - Apr 29th, 2007, 7:53am
Peter,
  Could you provide any additional information about the simulation
issue with the LDO? If Kirchoff's current law is not satisfied at a node,
does the simulaiton converge? Is there anything special about the
power down state? For example, does the circuit have hystersis in the
control loop? Are you performing a dc operating point calculation
or a dc sweep? If the simulation is just a dc operating point, you can try
using the simulator option gmethod=both. If you are running from inside
the environment, you can tirn off all the homotopy and manually set
homotopy=arclength.
