Sep 30th, 2024, 10:20am
How to simulate quantization noise in ADC (Read 4020 times)
paulcktang
Apr 28th, 2007, 4:15pm
I am working on simulating the noise of a quantizer. I want to know how to simulate the quantization noise and circuit noise by Cadence Spectre?
thanks at all!
Re: How to simulate quantization noise in ADC
Reply #1 - Apr 29th, 2007, 3:31am
Paul,
  It would be good to start by reviewing some of the previous threads on
the topic,
http://www.designers-guide.org/Forum/YaBB.pl?num=1102800907
If you setup the simulation correctly, then the effect of quantitazation
noise will be included in the simulation and will limit the noise floor at
the output of the ADC.
Simulating circuit noise is a more difficult problem, using Spectre you
can at least simulate the effect of jitter by using a noisy clock generator,
you will need to create it using verilog-A.
paulcktang
Reply #2 - Apr 29th, 2007, 10:52pm
Thanks! I read the previous thread but I still don't know the detial on how to setup the simulation of quantization noise in Spectre?
Do you think PNOISE analysis will be useful?
Or I have to compute the quantization error in time domain and then use FFT to compute the quantizaton noise spectrum?
Paul
Reply #3 - Apr 29th, 2007, 11:32pm
Quantization noise is a large signal phenomenon. You will need to use a transient analysis and an FFT.
