Sep 30th, 2024, 12:21pm
Noise analysis in Hspice (Read 3080 times)
Julian18
Apr 29th, 2007, 2:17am
Hi, there
     About Noise analysis in Hspice,
     the syntax is
                  .Noise vnod srcname inter
     now from the syntax, it seems that we must give .NOISE a source, but what if i just want to see the noise at output node due to,say,the channel noise of a MOS, or the noise of some resistors, while igoring all other noise sourses. how should i do
     BTB, what is the purpose of specifying a source to the .NOISE?to get the input refered noise? then since from textbooks(Tom Lee's book ), there are two input referred noise sources--input referred noise voltage& I/R noise current, how to tell which one it is?(since .NOISE just divides the output noise by the transfer function )
     i really screwed up . Can anyone help out there?
     thanks.
Julian
Re: Noise analysis in Hspice
Reply #1 - Apr 29th, 2007, 4:35pm
In most simulators you do not have to give the source, in which case it simply does not compute the input referred noise. I am not sure what HSpice does, but since you have it you can simply try it and see.
If you specify a voltage source, it should compute the input referred noise as a voltage. If you specify a current source, it should compute the input referred noise as a current.
Julian18
Reply #2 - Apr 29th, 2007, 6:47pm
Ken Kundert wrote on Apr 29th, 2007, 4:35pm:
Hi Ken:
    AFAIK, what HSPICE does is computing the total output noise and then dividing  it by the transfer function. so I may guess the computed input referred noise voltage/current will only be different by a factor of input impedance.
Julian.
