Julian18
Hi, there About Noise analysis in Hspice, the syntax is .Noise vnod srcname inter now from the syntax, it seems that we must give .NOISE a source, but what if i just want to see the noise at output node due to,say,the channel noise of a MOS, or the noise of some resistors, while igoring all other noise sourses. how should i do BTB, what is the purpose of specifying a source to the .NOISE?to get the input refered noise? then since from textbooks(Tom Lee's book ), there are two input referred noise sources--input referred noise voltage& I/R noise current, how to tell which one it is?(since .NOISE just divides the output noise by the transfer function ) i really screwed up . Can anyone help out there?
thanks.
Julian
