arunm
Chennai, India
Hello, I have an asynchronous, programmable divider chain in my PLL. I would like to estimate the phase noise contribution of the divider noise to the output. I am currently doing as follows: I am driving the divider chain with a frequency source and running a PSS + pnoise analysis. The fundamental frequency was set as the output frequency of the divider. My PLL spec has a noise limit at a frequency 'x' from the carrier. So, what I do now is note down the noise (in dBc/Hz as given by pnoise simulation) at frequency 'x' away from the output frequency of the divider and manually multiply it with the relevant transfer function to the output (it will be a lpf similar to ref noise). Is this procedure ok? I have a doubt as to how much I should set the maxsidebands value in pnoise. Should it be the divide value?
Thanks in advance, Arun
