May 18th, 2024, 11:19am
Hierarchy editor on IC5141USR4 on Debian (Read 2843 times)
pkhumsat
May 02nd, 2007, 11:10am
Dear all,
We have Cadence IC5141USR4 running on Debian Linux. When try creating a config-view file using Hierarchy Editor for simulation with parasitic extraction (av_extracted) but the following errors appear on an icfb command window saying:
WARNING: Unable to export the MPS service
Communications with other tools will not be possible
*WARNING* (ddsiInvokeHierEditor) unable to connect to hierarchy editor (60 tries)
Ton
PS. Everything seems to be running ok on RedHat 8.0
Re: Hierarchy editor on IC5141USR4 on Debian
Reply #1 - May 8th, 2007, 7:28am
Well, Debian is not a supported distro - so you're taking a risk there. Most likely something needs patching, but since Cadence don't test on Debian, it's hard to know what it is...
