Nov 1st, 2024, 1:11am
Gm-OpAmp-C integrator (Read 4789 times)
webb0111
May 04th, 2007, 9:57am
I have designed a two-stage Miller fully-differential amplifier, with cmfb.  It seems that all benchmarks that I need from opamp are met (BW, slew, gain).  I am having a problem with the common mode output voltage in a Gm-Opamp-C integrator.  I am using a -0.9V to 0.9V supply.  At dc, both the OTA and the opamp have 0.3V CM when connected together and separately.  The problem occurs as follows: when integrating the output CM slowly rises to around 0.75V for one end and 0.8V for the other end.
When using the opamp in an Active-RC integrator the circuit behaves as expected with CM at 0.3 for both ends.  Also, a Gm-C integrator behaves as expected with correct CM.  Simulations are done in Cadence.
Any reasoning as to why this is happening would be very helpful.  If more information is needed, I would be happy to oblige.
thanks, Matt
SATurn
Re: Gm-OpAmp-C integrator
Reply #1 - May 5th, 2007, 2:56am
Could you please put a plot describing this problem?
SATurn
webb0111
Reply #2 - May 7th, 2007, 9:49am
Here is the waveform image.  If allowed to run longer, Vop and Von tend tend get closer to each other.
SATurn
Reply #3 - May 7th, 2007, 1:01pm
What I can not exactly understand is that why the CM value of the blue and red waveforms are not 0.3? I suppose that the green and violet waves are outputs, but for the rest it is difficult to guess ...
SATurn
webb0111
Reply #4 - May 7th, 2007, 1:29pm
The blue wave form is the input, and the red waveform is the differential output (Vop-Von).  So the output should have CM of 0, like the input, assuming that the CM of output end is the same.
« Last Edit: May 7th, 2007, 4:10pm by webb0111 »
SATurn
Reply #5 - May 10th, 2007, 2:11pm
As it is evident from this figure, there should be a "systematic" "common mode" mismatch in the circuit! For example, one side draws more current respect to the other side from the Opamp. Meanwhile, maybe the CMFB circuit is not properly designed. For example it saturates or it is not well matched to the circuit ...
SATurn
