Jul 22nd, 2024, 1:23am
inconsistance between simulations (Read 3306 times)
Aigneryu
May 04th, 2007, 4:08pm
 Recently while I use spectre6.1.1 to simulate an osc with PSP model, I found the results can vary in a very strange fashion. My testbench is like following:
1. I use "width" as a variable for transistor width of which the default value is 10 (um).
2. Use parametric to sweep the width from 6 to 16 with step of 2.
3. I found the results of "width=10" are different in 1. and 2. And the difference can be up to 2 dB.
I did make sure the osc has enough time to settle, and set the accuracy requirement to 1e-6 relative, and 1e-8 absolute. I also check the netlist directly, but cannot find any discrepency.
Does anybody have any clue this kind of problem could happen? Maybe this is due to the computer or other things rather tahn simulator?
Sincerely,
Aigneryu
Re: inconsistance between simulations
Reply #1 - May 4th, 2007, 8:31pm
I found something: if I do "killall spectre" everytime before I run the simulation, the result will be the same. I tried this one different machines with different version of linux, they are all like this. And also, this technology has both BSIM and PSP, only PSP model has this problem. Does that mean this version of MMSIM has some bugs?
Sincerely,
Reply #2 - May 7th, 2007, 4:21am
It's quite possible (especially with an oscillator) to have a sensitive dependency on the initial conditions. When you're doing a sweep, the dc solution will start from the previous solution.
You might want to ensure that the transient or pss analysis you're using has "restart=yes", and also set the simulation option "rebuildmatrix=yes" (I think that's the parameter - I don't have access to spectre at the moment). "spectre -h options" will tell you what it's called.
Andrew,
Scott Flinchbaugh
Reply #3 - May 7th, 2007, 10:53am
All,
The Spectre options parameter is "rebuild_matrix=yes".
-scott
View Profile flinchba   IP Logged
Reply #4 - May 8th, 2007, 7:10am
Ah, close but no underscore...
Thanks Scott for correcting my memory!
