Aug 15th, 2024, 12:34pm
Layout Snap Spacing (Read 1576 times)
Faisal
Layout Snap Spacing
May 07th, 2007, 12:43am
In the Virtuso, Display options, through Layout Snap Spacing, I can control the X, Y snap spacing. What are the trade-offs or issues if I choose a too small snap spacing e.g. 0.001
The defualt X, Y snap spacing is at 0.5 but with this option I cannot place my PCELLS on the grid. I need the "RULER" for the layout rules etc and the RULER only works on the grid.
I am working on 0.18um. Has this something to do with the technology node?
Faisal
Re: Layout Snap Spacing
Reply #1 - May 7th, 2007, 1:29am
I get the following warning message, when I set my snapSpacing to 0.001 in Virtuso Display Options
*WARNING* 'ySnapSpacing' is not a multiple of 'mfgGridResolution' (0.005).
Can anyone explain what is the significance of mfgGridResolution?
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #2 - May 7th, 2007, 4:03am
This parameter is a foundry limitation, is their ability to place the masks on the wafer, if you make a smaller grid probably when you check the DRC of the layout you will find lots of errors about 'offgrid', if you don't correct this errors the foundry will refuse your fabrication order.
krishnap
Reply #3 - May 7th, 2007, 9:04pm
Usually process is done based on the MEBUS address unit. This is the minimum grid  upon which process is possible.
Any resolution below this manufacturing will not be possible.
Also, Raster scanning method is used in fabrication based on this address unit.
Faisal
Reply #4 - May 8th, 2007, 2:56am
Thanks, so it means the minimum snapSpacing i can choose is 0.005, as my mfgGridResolution (defined by technology file) is 0.005 ??
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #5 - May 8th, 2007, 2:59am
Yes, good luck with your layout.
