Jul 22nd, 2024, 4:30am
Pages: 1 2
using Eldo models in Spectre? (Read 26167 times)
Pavel
Lausanne/Switzerland
May 07th, 2007, 3:15am
How can I use Eldo models in Spectre simulator?
Is there some conversion program/script?
Pavel.
Re: using Eldo models in Spectre?
Reply #1 - May 7th, 2007, 4:18am
Pavel,
For the most part, they should work as is. spectre can read native SPICE models and usually would be able to read model files with no trouble.
Have you tried that? Just make sure that the file does not have a ".scs" suffix (otherwise that tells spectre to read it in spectre syntax) and include the file. Make sure you're using an MMSIM version (preferrably MMSIM61, since MMSIM60 is no longer supported).
Pavel
Reply #2 - May 7th, 2007, 7:06am
Andrew,
First, thank you for rapid answer.
Yes, I already tried it. I choosed Spectre as simulator and put +csfc option to force Spice syntax recognition.
But it was not sufficient. In Eldo model there are functions (for example trunc) that are not recognized by Spectre parser.
Moreover Eldo model of nmos/pmos contains directive Level=60. I searched for level 60 in Spectre Reference manual, but without success.
Pavel.
P.S. What is MMSIM and where can I find its version?
Reply #3 - May 7th, 2007, 8:18am
Every simulator has its own LEVEL system.  Do you know if level=60 in Eldo is supposed to be BSIM3, BSIM4, or something else?  I think these are level=49 and =54 respectively in "spice."  One can generally deduce the model by looking at the parameters that are specified, if one doesn't have the (Eldo) user's guide.
Pavel
Reply #4 - May 8th, 2007, 5:00am
Geoffrey,
First, thank you for response.
I compared liste of parameters of BSIM4 Spectre level 14 (from manual) with BSIM4 Eldo level 60 (form model from our Design Kit). There are quite a lot of differencies.
As number of parameters is huge (about 300), it's rather difficult (or time consumming) to establish correspondance.
Apart from this I've found in Design Kit file with extension .so, that sounds like model library. What is this file and can I use it?
I've noted that when I run simulation in ADE, first 5 lines in log window are:
Loading /mnt/ed/cadtools/lic5141_USR2.3/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so
Loading /mnt/ed/cadtools/lic5141_USR2.3/tools.lnx86/cmi/lib/4.0/libnortel_sh.so
Loading /mnt/ed/cadtools/lic5141_USR2.3/tools.lnx86/cmi/lib/4.0/libphilips_sh.so
Loading /mnt/ed/cadtools/lic5141_USR2.3/tools.lnx86/cmi/lib/4.0/libsparam_sh.so
Loading /mnt/ed/cadtools/lic5141_USR2.3/tools.lnx86/cmi/lib/4.0/libstmodels_sh.so
What this information means?
Pavel
Reply #5 - May 8th, 2007, 5:54am
Pavel wrote on May 8th, 2007, 5:00am:
That surprises me.  I know every simulator adds a few special flags, but it should be just a few.
Spectre is "nice enough" to ignore any parameters it doesn't know, so if you just change level=60 to level=14 you should be able to run it and see which one Spectre says it doesn't know (rather than checking all 300 individually).  You might also want to check the version= value; the default is not the latest, and it may ignore new parameters from the latest version if you don't set the version correctly.
.so is a "shared object" -- similar to a DLL in Windows.  Eg, the libphilips_sh.so contains the Mextram and PSP transistor models.
Pavel
Reply #6 - May 9th, 2007, 1:25am
Geoffrey,
Thank you fot hint. I tried it. For the moment I've problem with model syntax.
At the begining of Eldo model there is following piece of code
.SUBCKT ENULLMM9JU D G S B
+       param: W=10e-6 L=10e-6 nfing=1 mismatch=1 srcefirst=1
+       wfing={w/nfing+3.6e-08}
+       fd={srcefirst*(nfing-2*trunc(nfing/2))+(1-srcefirst)*(2*trunc(1+nfing/2)-nfing)}
+       fs={2-fd}
+       AD={wfing*(nfing*(5.2e-07-(-2.8e-08))/2+fd*(1.4e-07+(3.6e-08)/2))}
+       AS={wfing*(nfing*(5.2e-07-(-2.8e-08))/2+fs*(1.4e-07+(3.6e-08)/2))}
+       PD={nfing*2*(5.2e-07-(-2.8e-08))/2+fd*(wfing+2*1.4e-07+(3.6e-08))}
+       PS={nfing*2*(5.2e-07-(-2.8e-08))/2+fs*(wfing+2*1.4e-07+(3.6e-08))}
+       number=1
***MATCHING****
.PARAM vtor_alpha = {7.2e-09}
.PARAM vtor_beta  = {0}
.PARAM vtor_fudge  = {1}
.PARAM betsq_alpha = {1.85e-08}
.PARAM betsq_beta  = {0}
.PARAM betsq_fudge  = {1}
.PARAM vtor_sig = {((vtor_alpha/sqrt(W*L*number))+vtor_beta)*vtor_fudge/sqrt(2.0)}
.PARAM vtor_dev = 0.0 DEV/gauss = {vtor_sig*mismatch}
.PARAM betsq_sig = {((betsq_alpha/sqrt(W*L*number))+betsq_beta)*betsq_fudge/sqrt(2.0)}
.PARAM betsq_dev = 0.0 DEV/gauss = {betsq_sig*mismatch}
First I tried spice parser (option +csfe). It didn't like function trunc . The Spice homologue of Eldo trunc is int. When I replace trunc by int, spice parcer gives error.
Then I tried Spectre parser. I replaced .PARAM by parameters and trunc by floor. This was Ok. Problem rised with vtor_dev and betsq_dev parameters. For Spectre such syntax is uncomprehesible.
In which directio should I follow (adaptation to Spectre or Spice) and how could I circumvent problems mentionned above.
If I properly undestand you, the contents of this file is compiled models. So, it should be the way to use them? How?
Regards.
Pavel.
imd1
Reply #7 - May 9th, 2007, 1:45am
Your kit uses an intermediate step between the actual transistor instantiation and the model parameter call.
So your problem is this intermediate step (the .SUBCKT call). I'd expect Spectre's SPICE reader to undertand Int()... Do you have a HSPICE compatible option for the spectre reader?
DEV/gauss in the .param is an ELDO idiom to specify the pdf of that .param for Monte-Carlo simulation. If you don't care much for it at this step you could just remove it. Spectre has probably a totally different way to define a probability distribution for a simulation parameter, which in this case is not a model parameter, but simply a subcircuit parameter (local to the subcircuit...).
I'd skip this and just get the normal simulation to run, and study later how the ELDO way differs from the Spectre way.
The .so seem to be external models using the CMI (Compiled Models Interface). It's curious that they are being loaded at all, since you do not need those models in your circuit... Apparently Spectre has all its MOS models as CMI .so files.
I don't know if the CMI interface for Spectre is publicly documented, if that's your question. Do you want to write/compile new models for it?
Pavel
Reply #8 - May 9th, 2007, 4:22am
Hello imd1. Thanks for response. Some question concerning your advices.
What does "intermediate step" mean? When using Spectre parser I, of course, suppress the point.
So where is the problem? For Spice compatibility I use +csfe flag. With this flag Spice parser is used  (as I understood). But in this case another problem rises - trunc function. When I try replace trunc by int, parser gives an error.
I didn't really understand what is the contents of this file. It isn't loaded. I've just founded it it Design Kit.
My question is : can it be used in some way or not?
Regards.
Pavel.
Reply #9 - May 9th, 2007, 4:43am
imd1 wrote on May 9th, 2007, 1:45am:
A simpler structure would be something like
M1 d g s b nch l=0.18u w=10u
.MODEL nch nmos level=60
But you have an instance of "ENULLMM9JU" that resolves to a .SUBCKT rather than a .MODEL.  Indeed, I would try to figure out how to get the "nominal" simulation to run and then worry about mismatch later, as imd1 suggests.
I don't think BSIM3/4 are .so files.
It's not; last time I asked, Cadence wanted an NDA.  I think you also need a license key.
Reply #10 - May 9th, 2007, 4:48am
Pavel wrote on May 9th, 2007, 4:22am:
It will automatically be loaded if it is needed.  If you have
.model nch nmos level=14 vth0=0.7 ...
then this is a BSIM4 model, and the model equations that go with these parameters are built into Spectre.
If you have
model nch psp1020 tox=1.5n ...
then Spectre will load the philips .so file for the equations for the PSP model.  But the equations are useless without the appropriate parameters.
If you do a "spectre -help", near the end there is a list of components, with * for those that are loaded from shared objects (.so).
Pavel
Reply #11 - May 14th, 2007, 3:41am
I tried as you suggested - suppresed Monte-Carlo statements. I also changed parameter names to lowercase to be them compatible with Spectre bsim4 parameters. Then I tried to generate netlist for small test schema (please, see on the picture).
Results
- parser passes without errors
- nmos isn't present in netlist
- in Spectre log window I see following information:
Notice from spectre during topology check.
   Only one connection to the following 2 nodes:
       drain
       gate
Circuit inventory:
         nodes 3
         equations 5
         resistor 1
         vsource 2
Nmos isn't recognized, but parser passes without errors. Why?
Regards.
Pavel.
Pavel
Reply #12 - May 14th, 2007, 5:22am
Previous error is corrected. I included eldo in Switch & Stop View Lists in ADE/Setup/Environment Options/.
nmos appears in netlist.
Now problem is with model. Here is error message from spectre log window:
Error found by spectre during circuit read-in.
   "........./test_lib.lib" 126: Bad `subckt ... ENLLMM9JU' statement.
Where 126 is the last line in the file test_lib.lib.
it sounds like this:
ends ENLLMM9JU
what is conform with Spectre syntax.
Where is the problem?
Regards.
Pavel.
Reply #13 - May 14th, 2007, 6:38am
In spice format, it's .subckt and .ends; in spectre, there's no leading "."  I can't tell from your post which one you are intending to  use.  I don't remember whether either allows/requires/forbids having the subckt name on the "ends" line.
Pavel
Reply #14 - May 14th, 2007, 6:51am
Geoffrey,
I don't use leading "."
According to manual subckt name after ends is allowed. In any way I tried 2 options - with and without.
Regards.
Pavel.
Pages: 1 2
