Jul 22nd, 2024, 2:19am
Is there any variable for THD in HSPICE? (Read 3215 times)
blueband
China.Shanghai
May 24th, 2007, 8:08pm
Just like voltage, current, power and so forth, that we can plot/probe it. And it can be used in optimization.
And how can we use the harmonics in FFT analysis just as the other variables.
Re: Is there any variable for THD in HSPICE?
Reply #1 - May 31st, 2007, 7:07pm
It seems that the harmonics of FFT can not be used as other variables like voltage, current. However, please use them in any math tools like Matlab if you need any further measurement/calculation.
Yawei
Reply #2 - Jun 4th, 2007, 12:59pm
If you're using an optimizer around your simulation (for example, using ADE-GXL in IC610, or NeoCircuit in IC5141, or even the ADE optimizer in IC5141), you should be able to create a calculator expression which uses the dft() function and picks the value at a particular harmonic - and use that as a goal in your optimizer.
If you're hoping to do that within the simulator, that's going to be harder - although it's probably possible with spectreMDL using mvarsearch (which is effectively a simple optimizer). I've just never tried it myself.
blueband
China.Shanghai
Reply #3 - Jun 12th, 2007, 6:02pm
Thanks a lot!
