Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 22
nd
, 2024, 12:29am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Signal probing in the extracted view
Previous topic
Next topic
Signal probing in the extracted view (Read 3446 times)
eng
USA
Jun 13
th
, 2007, 8:03am
Does anybody know how to probe the signals on some nets in the extracted view?
IP Logged
boe
Re: Signal probing in the extracted view
Reply #1 -
Jun 14
th
, 2007, 1:37am
Hi eng,
Which tools do you use?
BOE
IP Logged
eng
USA
Reply #2 -
Jun 14
th
, 2007, 1:24pm
Hi Boe,
I'm using Cadence for both schematic and layout. The process is IBM. For verification I generally use Diva. However I do have access to Assura as well.
thanks
IP Logged
boe
Reply #3 -
Jun 14
th
, 2007, 5:00pm
Hi eng,
If you run an LVS (Diva) first, you can use lvsbx (a Cadence program, it gives a help message when run wo parameters) to annotate the node names etc from the schamtic to the extracted.
I hope this helps.
BOE
IP Logged
Reply #4 -
Jun 14
th
, 2007, 8:35pm
Eng,
Have you tried probing from the schematic? This capability was added
a while ago, you need to see the manual for details.
To start the
Select Tools --> Parasitics in Composer to activate the Parasitics menu
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
