Pavel wrote on May 18th, 2007, 5:42am:I followed your suggestion. Error message is the same.
What version of Spectre are you running?
Quote:Moreover, I changed "continue line" from "+" to "\" (as it seems that last one is more credible)
When I tried your latest file, the \ didn't work because you left in the comment lines "//-----------"
I also found that sometimes it's important not to start on the first line -- spice has a "tradition" of ignoring the first line, so I always start my files with a line containing only "* name of circuit" or "// name of circuit". If you have the simulator lang statement there, it's not clear to me if spectre will read it.
Can you run the attached?
