Matt,
If your models are reasonably accurate, it seems like this approach should work. You might need to calculate the RMS current since the current may vary as a function of time. Certainly, you can repeat the analysis across corners, PVT, to get more accurate results. Could you share your reasons for believing that this calculation is not correct?
