Aug 17th, 2024, 11:14pm
how to simulate the stability of LDO(connected wit (Read 2603 times)
wave3x
Shang Hai, China.
May 08th, 2007, 7:51pm
because VCO always change the frequence
Re: how to simulate the stability of LDO(connected
Reply #1 - May 9th, 2007, 5:25am
Wave,
  Never tried this configuration before, but SpectreRF
periodic stability analysis should be able to calculate
the stability characteristics of the circuit. To use,
1) Calculate the periodic operating point, that is, run
   autonomous PSS
2) Run Periodic stability analysis, pstab
In the past, I have used this analysis to calculate the
gain and phase margin of dynamic circuits, for example,
DC-to-DC Converters and VCOs. You just need to make
that you correctly define the loop.
wave3x
Shang Hai, China.
Reply #2 - May 9th, 2007, 6:20pm
thanks
