Aug 17th, 2024, 11:12pm
Strain & mobility (Read 4299 times)
mg777
Strain & mobility
May 08th, 2007, 9:43pm
In sub-90 nm CMOS processes, mobility is incerased by creating channel stress - tensile for n-channel and compressive for p-channel. It's interesting that electrons and holes need opposite types of stress. I was trying to figure out this behavior intuitively.
Electrons are in the conduction band and their mobility is limited by atomic scattering. So further apart the atoms less the scattering. Now why doesn't this same logic hold for holes? Because holes are in the valence band, more or less orbiting the silicon atoms. The valence band is formed because of Si-Si covalent bonds whereby valence electrons can tunnel from atom to atom, forming propagating wave functions in the periodic potential of the lattice. Ergo, the closer the atoms the easier the atom-hopping.
So, electrons and holes are indeed very different beasts.
M.G.Rajan
www.eecalc.com
Croaker
Re: Strain & mobility
Reply #1 - May 17th, 2007, 6:46am
Good explanation!   Smiley
krishnap
Reply #2 - May 22nd, 2007, 6:03am
Hi Rajan,
Good concept.
Usually how the tensile and compressive stress are formed?
By varying the doping concentration?
Reply #3 - May 23rd, 2007, 4:49am
krishnap wrote on May 22nd, 2007, 6:03am:
No.  The "STI stress effect" is a compressive stress caused by the (shallow trench isolation) oxide around the device.  LOCOS (local oxidation of silicon) also causes it, because the oxide takes up more room than the silicon it was oxidized from, but most foundries switched from locos to sti before the device sizes got small enough that anyone noticed the effect.
Lattice mismatch is another way to get stress: grow your Si device on Ge or SiGe.  I think there's also something in the literature about the gate oxide (or nitride?) applying a stress.
krishnap
Reply #4 - May 23rd, 2007, 6:56am
Hi  Geoffrey, Thanks for the explanation
