Hi, Guys,
I use an ideal ADC to quatize sine wave of ramp signal when I simulate a current-steering DAC. The ideal ADC is written in Verilog-A and modified based on the 8-bit ideal ADC (adc_10bit_ideal) in ahdlLib. I increased the number of bit to 10, and lower the transition voltage to 0.9V. The rise and fall time defined are both 0. However, I simulated using Spectre and the rise and fall time are both 18ns. It caused some errors in my simulation.
Because I cannot copy the file from company's workstation, I rewrite some of the file below.
// adc_10bit_ideal // // vin: [V,A] // vclk: [V,A] // vd0..vd9: data output terminals [V,A] // // Instance parameters // tdel , trise, tfall = {usual} [s] // vlogic_high = [V] // ... // vtrans_clk = clk high to low transition voltage [V] // vref = ...
module adc_10bit_ideal(vd9, vd8, vd7, vd6, vd5, vd4, vd3, vd2, vd1, vd0, vin, vclk); electrical vd9, vd8, vd7, vd6, vd5, vd4, vd3, vd2, vd1, vd0, vin, vclk; parameter real trise = 0 from [0:inf); parameter real tfall = 0 from [0:inf); parameter real tdel = 0 from [0:inf); parameter real vlogic_high = 1.5; parameter real vlogic_low = 0; parameter real vtrans_clk = 0.9; parameter real vref = 1.0;
`define NUM_ADC_BITS 10 real unconverted; ....
// assign the outputs
V(vd9) <+ transition ( vd[9], tdel, trise, tfall ); ...
`undef NUM_ADC_BITS end endmodule
What's wrong with my simulation? Any comments are appreciated.
Best regards, Yawei
