Sep 11th, 2024, 2:21am
regarding DAC output impedance calculation (Read 4302 times)
venki_vlsi
warangal
May 13th, 2007, 9:32pm
hi,i am designing 10 bit DAC with sinlge ended output.
I want to know how much output impedance is required  for single current source to acheive sfdr of 60db and inl of 1 lsb.
I searched many papers ,they r giving for differenctial output impedance. Is there any relation to find outimpedance for single ended ouput i from differenal output  having same sfdr and inl. I am not sure if this valids ( 2*differentaloutput impedance=single ended outout imopedance).
Thanks in advance.
s.venkat_nitw
Re: regarding DAC output impedance calculation
Reply #1 - May 15th, 2007, 1:24am
venki,
Just calculate the output impedance regardless your DAC is differential output or single-ended output. If your DAC is single-ended output, the result is impedance for single-ended output. If your DAC is differential, the result is impedance for differential output. I think so.
Yawei
venki_vlsi
warangal
Reply #2 - May 16th, 2007, 2:12am
Thanks for ur reply.
s.venkat_nitw
neoflash
Mixed-Signal
Designer
Reply #3 - Mar 22nd, 2011, 10:47pm
venki_vlsi wrote on May 13th, 2007, 9:32pm:
Thanks in advance.
Single ended and differential current steering DAC suffer distortion from different mechanism.
Differential DAC can cancel HD2 and suffer only HD3 which is a lot lower.
Single ended DAC suffer HD2 which is approximated by
(RL/Ru)*2^N/4
