Jul 22nd, 2024, 2:28pm
Need help on PTV mebedded single deck (Read 2081 times)
kiran123
May 15th, 2007, 2:10am
Hi Experts,
       I am doing spectreMDL PTV based simulations i.e 3 PTV (fast,cold,normal) in same deck as listed below (File1.scs) ( i have just embedded deck and MDL code in same file for simplicity) but for slow and strong i observed there is difference of getting value if i use standalone SpectreMDL deck as shown by File2.scs.
 Can  anybody let me know is there any declaration error  in the File1.scs
Best Regards
Kiran Kumar
/-----------------------------------     File1.scs     -------------------------------------------------------------------------
simulator lang=spectre
global 0
include "Models_tt.scs"
include "INV.scs"
parameters  VA=1.2
parameters  VH=3.3
parameters  Temp=25
OP_TT  options temp=Temp
vvdds (VDDS VSS) vsource type=dc dc=VH
vvss (VSS 0  ) vsource type=dc dc=0
va (IN  0  ) vsource type=dc dc=0
X1 ( OUT VDDS VSS IN ) INV
dc_sweep dc print=yes
save IN  OUT  VDDS VSS Isour:currents Vsour:currents
ff_for altergroup {
parameters  Temp=-40
include "Models_ff.scs"
parameters VA =1.32
parameters VH =3.6
//dc_sweep_FF dc print=yes
ss_for altergroup {
parameters  Temp=125
include "Models_ss.scs"
parameters VA =1.08
parameters VH =3.0
//dc_sweep_SS dc print=yes
////****************  MDL File *****************///////
alias measurement VOH {
   export real Voh
   run dc_sweep
    Voh = max(V(OUT))
run dc_sweep
run VOH as VOH_TYP
run  ss_for
run VOH as VOH_SLOW
run  ff_for
run VOH as VOH_FAST
/************************************* END ***********************************/
/-----------------------------------     File2.scs     -------------------------------------------------------------------------
global 0
include "INV.scs"
parameters  VA=1.08
parameters  VH=3.0
parameters  Temp=125
   export real Voh
   run dc_sweep
    Voh = max(V(OUT))
run VOH
Re: Need help on PTV mebedded single deck
Reply #1 - Jun 4th, 2007, 8:12pm
Hi, Kiran,
That is interesting. What is the difference?
Yawei
kiran123
Reply #2 - Jun 5th, 2007, 1:06am
ywguo wrote on Jun 4th, 2007, 8:12pm:
Hi, Kiran,
Yawei
Hi Yawei,
       It nice to see one response after a long time since i posted this , here  i have pasted the data
using "File1.scs" ( 3 corner simulations in same deck )
Measurement Name   :  VOH_TYP
Voh                =  2.93726
Measurement Name   :  VOH_SLOW
Voh                =  2.54443
Measurement Name   :  VOH_FAST
Voh                =  3.29538
using "File2.scs" the weak corner simulations results
Voh                =  2.40291
you can see the difference of values of Slow corner is significant , so i am just expecting what is the currect way of declaration of corner simulations (if want to define coner to corner PTV)
Thanks & Regards
Kiran
