Sep 24th, 2026, 4:07pm
Temp in Corners analysis (Read 3367 times)
May 16th, 2007, 6:18pm
Hi, Guys,
I use Corners Analysis in ADE. I fill in 25, -40, and 125 for typ, fast, and slow corners respectively. One more parameter named supply is defined for supply voltage variation. That is 1.8, 1.9, 1.7 for typ, fast, and slow corners respectively. The corners analysis works fine.
However, I do not find temp parameter in altergroup when I take a look at input.scs. In my input.scs file, the altergroup is shown like the following.
fast altergroup {
 parameters supply=1.9
 include \
   ".............model.scs" \
Which file is the parameter temp defined in when I run a corners analysis in ADE?
Thank you
Yawei
kiran123
Re: Temp in Corners analysis
Reply #1 - May 18th, 2007, 5:53am
hi yawei,
        If your question is on how to include temperature variations in the input.scs file please have a look at my posting  subject name : Need help on PTV mebedded single deck
Reply #2 - Jun 4th, 2007, 12:17pm
Yawei,
The input.scs file that you get when you use the corners tool is not exactly how it would be done if you run spectre standalone. This is because the corners tool talks to spectre interactively, and tells it to:
use a named altergroup
set the temperature
run the named analyses
use the next names altergroup
set the next temperature
run the named analyses again
Normally you'd repeat the analyses between each altergroup, and set the temperature directly - but the interactive MPS (Message Passing Subsystem) (effectively a form of Remote Procedure Call) allows the corners tool (or ADE) to control spectre directly.
It's somewhat unfortunate that it's done this way, because it makes life a little hard for us application engineers to debug corners problems in the simulator without a fairly complete testcase - although there are ways and means  ;) . However, despite the fact that the netlist doesn't show the temperature changes, it should actually change in practice!
Reply #3 - Jun 4th, 2007, 7:18pm
Hi, Andrew,
That is life. Smiley Thank you.
Yawei
