Aug 15th, 2024, 12:32pm
join strings (Read 4247 times)
Croaker
join strings
May 15th, 2007, 11:13am
How do you join strings with Verilog-A?
str1 = "a";
str2 = "b";
I want to have str3 = "ab".
Re: join strings
Reply #1 - May 16th, 2007, 7:29am
You can't do this presently, not least because Verilog-A doesn't really have strings in the first place.
Verilog-AMS has "string literals" from digital Verilog, which can be stored in "reg" variables (registers) of 8 bits per character, and these registers act as though they are integers.  Verilog-A specifically excludes reg.
DReynolds
Scarborough ME
Re: join strings
Reply #2 - May 17th, 2007, 10:19am
Croaker, as mentioned, the language really doesn't deal with string manipulation: I have found it easier to do my string manipulations in another language (python, perl, skill) and then just dump it into a file that I stitch into the veriloga.
David
chetan
Re: join strings
Reply #3 - May 30th, 2007, 11:55am
Verilog-A does allow string variables ( plane variables - apart from the registers ) as well as parameters. The string parameters are treated differently than variables. For joining the strings the concatenation operator works.
I've already anwsered a similar post titled ' string variables in Verilog-A'. See if this link works: http://www.designers-guide.org/Forum/YaBB.pl?num=1177696583
That post gives an example.
Re: join strings
Reply #4 - May 31st, 2007, 3:47am
chetan wrote on May 30th, 2007, 11:55am:
No, it doesn't -- it's not part of LRM 2.2.  The V-AMS committee is working to include them in LRM 2.3, based on the definition in SystemVerilog.
Perhaps your simulator has an extension that allows string variables?
