Sep 30th, 2024, 12:19am
Folded Cascode : Sizing of Devices (Read 566 times)
raduga
May 16th, 2007, 5:32am
Hi All,
I am designing a floded cascode amplifier. It is a diff. input and single ended
output.   I have one doubt there. If I would like to keep the output voltage
at the middle of the o/p swing range then how you should size the 4 transistors
quickly to get that point. Can any one give me his/her methdology.
Thanks in advance.
Raduga
mosman
china
Re: Folded Cascode : Sizing of Devices
Reply #1 - May 18th, 2007, 1:05am
the size of transisitors is based on the gain and BW. basically we want to get tahe gain as larger as possible. usually, gain equals gm*Rout. so you should increase the rout and gm. the cascode configure's rout is inverse to the biasing current, and propotianl the Longth. for gettting the larger Rout decreasing the biasing current of out colume is a good idea. meanwhile, you need increase the input biasing tail current to increas the gm. but too large ratio is very good. some experencided designer advizes the ratio should be 3~4.
best regards,
View Profile mosman   IP Logged
