Nov 1st, 2024, 3:20am
Varactors in CMOS process. (Read 1425 times)
eng
USA
May 19th, 2007, 2:51pm
What are the differences between MOS varactor and hyperabrupt junction varactor? I need to use a varactor for tunability in my baseband filter. The process I'm using has these two. The supply voltage is 1V and cutoff freq is subMHz and process is 0.18um. Which varactor is more suitable for my case?
chase.ng
penang/malaysia
Re: Varactors in CMOS process.
Reply #1 - May 20th, 2007, 9:33pm
Depends on your application, the hyperabrupt junction varactor normally has larger tuning range, but the Q might not be very good. Your process design kits will have details regarding these numbers.
regards,
chase
Chase
View Profile chase.ng   IP Logged
