Sep 15th, 2026, 7:04pm
Pages: 1 2
Fourier analysis and DFT compare (Read 22620 times)
RobertZ
the art of analog
San Diego, CA
May 20th, 2007, 10:33pm
I did two simulations using ideal 10 bits ADC and DAC, and check the spectrum at the ideal DAC output.
1st one, fclk = 32MHz, fsig = 1MHz, DFT and Fourier analysis results match each other.
2nd one, fclk = 32MHz, fsig = 0.96875MHz. The Fourier analysis using the last period (38.9677us ~ 40us) to find the fourier coefficients. If I use the same period for DFT, the results match, as expected. If I use 8us to 40us to do DFT, which is exactly 31 periods (32us length), the DFT result shows less magnitude at harmonics. I would trust the DFT result more for the 2nd case. Any one can comment on this?
Thanks!
Robert
Re: Fourier analysis and DFT compare
Reply #1 - May 23rd, 2007, 3:47am
Driveforce,
  Some comments:
1) You using a fourier command like
    FOUR0 ( out 0)  fourier fund=968710.6461  harms=??
   As mentioned in one of the previous appends, it would be better
   to add the normharm property to the symbol
   FOUR0 ( out 0)  fourier fund=31250 harms=1024  normharm=31
   This will allow a direct comparison of the DFT and Fourier analysis
    results. Currently the analysis use different fundemental frequencies.
2) The period appears to be a little off, (31/1024)*32MHz = 968750Hz,
   1/(40us-39.9677us)=968710.6461 Hz and this could result in spectral
   leakage that requires windowing. The Fourier component does not
   include a windowing function so you need to be careful about frequency
   selection.
3) An ideal DAC has quantitazation noise not distortion harmonics so you
   need to compare snr ( or sinad) in order to verify the results.
4) For non-ideal DACs, the results would not be expected to match since
   the DFT samples the waveform, i.e., that is it is difficult to capture the
   the effect of glitch impulse on the response. The Fourier component
   integrates over the waveform and is more suited for this measurement.
RobertZ
the art of analog
San Diego, CA
Reply #2 - May 23rd, 2007, 4:17pm
Hi, Sheldon,
Thanks for your reply.
1) I didn't use fourier command, and don't know hwo, instead, I use fourier analysis in GUI, as shown in the following. The plus terminal should be connected output, not ground.
2) the period is automaticlly set by the fourier analysis. At the end of the analysis, it showed 307.434 m% mismatch between period begins and ends.  ls this causing spectrum leakage?
Thanks.
Fourier Analysis `FOUR0'
Fundamental frequency = 968.75 kHz.
Fundamental period = 1.03226 us.
Fourier components of V(net016) for the interval from 8.96774 us to 10 us:
DC = 412.951 mV.
Harm:  Absolute        Absolute        Relative        Relative
      Magnitude       Phase           Magnitude       Phase
  1:  412.944 mV     -95.4565 Deg     0.000 dB        0 Deg <- normalizer
  2:  245.753 uV     -155.438 Deg    -64.508 dB      -59.9814 Deg
  3:  154.551 uV     -127.679 Deg    -68.536 dB      -32.2226 Deg
  4:  136.333 uV      70.9494 Deg    -69.626 dB       166.406 Deg
  5:  167.488 uV      127.225 Deg    -67.838 dB       222.682 Deg
  6:  70.1281 uV      50.7072 Deg    -75.400 dB       146.164 Deg
  7:  143.164 uV     -4.80259 Deg    -69.201 dB       90.654 Deg
  8:  85.7771 uV     -167.751 Deg    -73.650 dB      -72.2944 Deg
  9:  57.4369 uV      85.7145 Deg    -77.134 dB       181.171 Deg
 10:  58.2287 uV      58.7229 Deg    -77.015 dB       154.179 Deg
 11:  96.982 uV      -140.591 Deg    -72.584 dB      -45.1347 Deg
 12:  112.673 uV     -151.425 Deg    -71.281 dB      -55.9682 Deg
 13:  48.6384 uV     -81.8236 Deg    -78.578 dB       13.633 Deg
 14:  73.3771 uV      139.605 Deg    -75.007 dB       235.062 Deg
 15:  95.3559 uV     -131.078 Deg    -72.731 dB      -35.6217 Deg
 16:  75.5083 uV     -27.9219 Deg    -74.758 dB       67.5347 Deg
 17:  27.7394 uV      40.3701 Deg    -83.456 dB       135.827 Deg
 18:  10.836 uV       114.367 Deg    -91.620 dB       209.823 Deg
 19:  29.4197 uV      24.4814 Deg    -82.945 dB       119.938 Deg
 20:  75.3786 uV      78.4791 Deg    -74.773 dB       173.936 Deg
 21:  40.8751 uV      159.28 Deg     -80.089 dB       254.737 Deg
 22:  88.73 uV        12.2185 Deg    -73.356 dB       107.675 Deg
 23:  58.7199 uV      111.711 Deg    -76.942 dB       207.168 Deg
 24:  96.3994 uV     -151.858 Deg    -72.636 dB      -56.4017 Deg
 25:  65.5622 uV     -14.3222 Deg    -75.985 dB       81.1343 Deg
 26:  56.5478 uV      63.265 Deg     -77.270 dB       158.721 Deg
 27:  110.388 uV     -157.099 Deg    -71.459 dB      -61.6427 Deg
 28:  87.8713 uV     -56.0377 Deg    -73.441 dB       39.4189 Deg
 29:  127.44 uV       70.3307 Deg    -70.212 dB       165.787 Deg
 30:  193.419 uV      173.36 Deg     -66.588 dB       268.817 Deg
Total harmonic distortion = 138.224 m% (-57.1883 dB).
RMS value of computed spectrum (excluding DC) = 412.945 mV.
RMS value of computed spectrum (including DC) = 583.996 mV.
Nonperiodicity (first/last point mismatch) = -1.26953 mV (-307.434 m%)
sheldon wrote on May 23rd, 2007, 3:47am:
Driveforce,
  Some comments:
   selection.
Robert
venki_vlsi
warangal
Reply #3 - May 23rd, 2007, 5:30pm
hi drive force,
i too using the same method(fourier compnent in GUI) in calculating distortion.
For Fs=125MHZ Nc=83,Ns=1024, i got Fin=10.1318Mhz
Since my Nc=83,i have to run my simulation for 83 clcok cycles(83*(1/10.1318M=8.192u ) with trans=0 to 8.192us.
I am getting good sfdr.but problem is with distortion and non periodic  mismatch.
any commnets on these how to improve.
Fourier Analysis `FOUR1'
Fundamental frequency = 10.1318 MHz.
Fundamental period = 98.6991 ns.
Fourier components of V(OU) for the interval from 8.0933 us to 8.192 us:
DC = 495.933 mV.
  1:  494.736 mV     -105.375 Deg     0.000 dB        0 Deg <- normalizer
  2:  4.28339 mV     -174.911 Deg    -41.252 dB      -69.5364 Deg
  3:  5.55389 mV      178.646 Deg    -38.996 dB       284.021 Deg
  4:  5.43339 mV     -170.83 Deg     -39.186 dB      -65.4553 Deg
  5:  5.19213 mV     -171.569 Deg    -39.581 dB      -66.1937 Deg
  6:  5.68695 mV     -168.216 Deg    -38.790 dB      -62.8415 Deg
  7:  6.41957 mV     -166.124 Deg    -37.737 dB      -60.7492 Deg
  8:  7.52246 mV     -160.438 Deg    -36.360 dB      -55.0634 Deg
  9:  9.12129 mV     -158.374 Deg    -34.686 dB      -52.9991 Deg
Total harmonic distortion = 3.61018 % (-28.8494 dB).
RMS value of computed spectrum (excluding DC) = 495.058 mV.
RMS value of computed spectrum (including DC) = 700.737 mV.
Nonperiodicity (first/last point mismatch) = 78.125 mV (15.7913 %).
Total time required for tran analysis `tran' was 1.18 s.
finalTimeOP: writing operating point information to rawfile.
s.venkat_nitw
RobertZ
the art of analog
San Diego, CA
Reply #4 - May 23rd, 2007, 8:59pm
Hi, venki_vlsi,
Why did you get 15.7913% mismatch?
Did you using real circuit or ideal block?
By the way, Fin =  10.1318MHz may not be accurate enough for your calculation.
venki_vlsi wrote on May 23rd, 2007, 5:30pm:
hi drive force,
DC = 495.933 mV.
Robert
venki_vlsi
warangal
Reply #5 - May 23rd, 2007, 9:23pm
hi ..
its for actual ckt only.
Can u plz tell me how to improve non-periodic mismatch.
I tired to improve distortion to 44 db not more than that.my spec is 55 db.
s.venkat_nitw
RobertZ
the art of analog
San Diego, CA
Reply #6 - May 23rd, 2007, 11:00pm
What is your clock frequency?
I ran a simulation with fclk = 125MHz, fin = 10.1318MHz. The fourier analysis shows no periodic mismatch.
Fourier components of V(net016) for the interval from 9.9013 us to 10 us:
DC = 413.282 mV.
  1:  409.473 mV     -104.721 Deg     0.000 dB        0 Deg <- normalizer
  2:  660.32 uV       155.756 Deg    -55.849 dB       260.477 Deg
  3:  387.222 uV      32.5348 Deg    -60.485 dB       137.256 Deg
  4:  544.762 uV     -81.4079 Deg    -57.520 dB       23.3131 Deg
  5:  706.288 uV     -167.658 Deg    -55.265 dB      -62.9373 Deg
  6:  1.01321 mV      88.3409 Deg    -52.131 dB       193.062 Deg
  7:  988.561 uV     -16.361 Deg     -52.344 dB       88.36 Deg
  8:  1.39653 mV     -119.413 Deg    -49.344 dB      -14.6925 Deg
  9:  2.32906 mV      132.577 Deg    -44.901 dB       237.299 Deg
Total harmonic distortion = 801.097 m% (-41.9263 dB).
RMS value of computed spectrum (excluding DC) = 409.487 mV.
RMS value of computed spectrum (including DC) = 581.792 mV.
Nonperiodicity (first/last point mismatch) = 0 V (0 %)
[quote author=venki_vlsi link=1179729208/0#3 date=1179970201]hi drive force,
Robert
venki_vlsi
warangal
Reply #7 - May 23rd, 2007, 11:18pm
hi Drive force.
Thanks a lot.
What is simulation time?I ran from 0-8.192us..Its basically 83 intergercycles.
Its looks u run more than 83 cycles from dats u have copied.
How r u choosing simulation time?
regards
venkats
s.venkat_nitw
RobertZ
the art of analog
San Diego, CA
Reply #8 - May 23rd, 2007, 11:46pm
at first, I ran simulation with ideal blocks.
The simulation time is 10us. For your case, real circuits, you may want to run more than 10us, since it need some time to settle down. Maybe that's the reason you had periodic mismatch.
But no matter how long the simulation time, fourier analysis automatically chooses the last fundamental period to do calculation.
Again, what is your clock frequency?
Robert
venki_vlsi
warangal
Reply #9 - May 24th, 2007, 12:07am
My clock frequency is 125Mhz.
I understood where i went wrong.
previously i  tried with dc voltage of 1.65 and amplitude of 1.65 to input sinewave so,i am getting nonperiodic mismatch.
now i tried with dc voltage of 0 and amplitude of 3.3v,i am not getting any non periodic mimsmatch but distortion is less when compared with previous case.
sorry for my english.
thanks driveforce.
s.venkat_nitw
Reply #10 - May 24th, 2007, 2:25am
Venki,
  Not sure that the dc level matters since the Fourier component
accounts for it. Here is the setup for your case.
NOTE:
To avoid accuracy issues, my testbench uses design variables:
numPoints --> number of points in the FFT, 1024
tones        --> input signal tone, 83
fsample    --> sample rate, 125M
so the Fourier component
fundamental frequency ==> fsample/numPoints
number of harmonics   ==> numPoints/2
normharm                   ==> tone
This minimizes setup since all the variables are controlled from ADE,
makes the testbench re-usable, and eliminates the accuracy issue.
RobertZ
the art of analog
San Diego, CA
Reply #11 - May 24th, 2007, 10:35am
Sheldon,
I understand what your normharm means now.
But I couldn't find where to set it. My Fouier analysis always takes fundamental frequency as normalizer.
Here is the what I found in the netlist.
FOUR0 (net016 0) fourier fund=125M/1024 points=300 active=yes order=2 \
       harms=512 refharms=83 scale=1
and the analysis print out likes this:
Fundamental frequency = 122.07 kHz.
Fundamental period = 8.192 us.
Fourier components of V(net016) for the interval from 1.808 us to 10 us:
DC = 412.985 mV.
  1:  24.0204 uV     -28.2579 Deg     0.000 dB        0 Deg <- normalizer
  2:  12.7912 uV     -122.369 Deg    -5.473 dB       -94.1112 Deg
  3:  32.1999 uV     -170.419 Deg     2.545 dB       -142.161 Deg
  4:  23.918 uV       42.1886 Deg    -0.037 dB        70.4465 Deg
81:  37.8771 uV      98.2271 Deg     3.956 dB        126.485 Deg
 82:  48.8834 uV     -54.2941 Deg     6.172 dB       -26.0361 Deg
 83:  409.158 mV     -104.695 Deg     84.626 dB      -76.4374 Deg
 84:  24.6046 uV      76.1291 Deg     0.209 dB        104.387 Deg
 85:  46.3879 uV     -93.9173 Deg     5.716 dB       -65.6594 Deg
2nd question, how do you plot the fourier analysis output. It is only printed out into the output.log file.
3rd question, how do you use the window function? I only know the window function is availbe if I do FFT.
Thanks a lot!
Robert
venki_vlsi
warangal
Reply #12 - May 24th, 2007, 6:40pm
hi..
i too have used same test bench but we differ in giving values to fourier component.
can u clear me doubts in ur fourier component setup.
1.fundamental frequency ==> fsample/numPoints.
(I have given fin(10.1318Mhz) as fundemental frequency in fourier component.can u plz clear me why we should we use fundemental as fsample/number of points).
2.number of harmonics   ==> numPoints/2
(i have not mentioned any hormonic number in fourier component.its default showing 10 hormonics.I feel higher order hormonics doesnt effect much.Should we take 512 as default number in fourier componenet).
3.rmharm                   ==> tone
( i have not mentioned any refernce hormonic as i didnt understood what it means. can u give me little more details).
i too have done simulation with ur setup and results r getting differed.can u plz have a look.
Fundamental period = 8.19202 us.
Fourier components of V(OU) for the interval from 1.80798 us to 10 us:
DC = 498.416 mV.
  1:  19.2405 uV     -4.53968 Deg     0.000 dB        0 Deg <- normalizer
  2:  8.87069 uV     -151.694 Deg    -6.725 dB       -147.154 Deg
  3:  64.5489 uV      96.2625 Deg     10.513 dB       100.802 Deg
  4:  9.9571 uV      -112.919 Deg    -5.722 dB       -108.38 Deg
508:  39.9502 uV      18.8854 Deg     6.346 dB        23.4251 Deg
509:  75.2377 uV     -160.875 Deg     11.844 dB      -156.335 Deg
510:  14.0832 uV      127.099 Deg    -2.710 dB        131.639 Deg
511:  8.52414 uV     -68.0349 Deg    -7.071 dB       -63.4953 Deg
512:  5.03811 uV      162.856 Deg    -11.639 dB       167.395 Deg
Total harmonic distortion = 2.5702 M% (88.1994 dB).
RMS value of computed spectrum (excluding DC) = 494.52 mV.
RMS value of computed spectrum (including DC) = 702.117 mV.
Nonperiodicity (first/last point mismatch) = 0 V (0 %).
if u observe clearly my normaliser point is at 1st hormonic and ur normaliser point is at 83 hormonic.How ru able to acheive at that point)
these results r with setup as shown in fig.
Thanks and regards
venkat
sheldon wrote on May 24th, 2007, 2:25am:
Venki,
NOTE:
normharm                   ==> tone
« Last Edit: May 24th, 2007, 11:52pm by venki_vlsi »
s.venkat_nitw
RobertZ
the art of analog
San Diego, CA
Reply #13 - May 24th, 2007, 10:18pm
Hi, venki,
you should look at tone 83, which is your signal position, and your signal's harmonics are at 83x2, 83x3.... Sheldon's idea is very clever.
setting fundamental equal to fsample gives long window (8.192u), which is also what you want.
regards,
driveforce
Robert
venki_vlsi
warangal
Reply #14 - May 27th, 2007, 8:29pm
hi sheldon and driveforce
can u tell me how u have got normaliser point is at 83rd hormonic  while i got it at 1st hormonic. fourier component  results  r shown below.
DC = 498.416 mV.
regards
venkats
s.venkat_nitw
Pages: 1 2
