Oct 31st, 2024, 11:02pm
RSSI (Read 1198 times)
aaron_do
RSSI
May 21st, 2007, 1:49am
i'm designing a receiver signal strength indicator (RSSI) in analog, and i've got a question. One way to do the RSSI is to have a log amplifier followed by peak detection. The log amp usually consists of a series of limiting amplifiers with each of their outputs added together. So I noticed that for N limiting amplifier stages, most designers used N peak detectors and then added the DC signals together. However, to save power, I want to add the AC signals together and have one peak detector. Does anyone know why this isn't normally done?
thanks,
Aaron
didac
There's a million
ways to see the
things in life
manresa,spain
Re: RSSI
Reply #1 - May 21st, 2007, 2:37am
I don't know for sure but I suppose that it's caused due to phase effects. If you sum DC signals(all with the same sign) you will have the maximum, if you sum AC signals each one will probably have a slight delay with the previous one(seen in a transient point of view) or a different phase(seen in a frequency point of view) due to the amplifier chain, in this case if you sum AC signals not in phase you won't obtain the maximum.
ACWWong
Oxford, UK
Re: RSSI
Reply #2 - May 21st, 2007, 6:52am
i agree with didac, also most of the limiting amp structures give you a simple peak recified level (for no or next to no extra power consumption) which when added together gives a good piecewise linear rssi.
out-of-interest, how would you propose to "add the AC signals together" ?
Re: RSSI
Reply #3 - May 21st, 2007, 11:17am
aaron_do wrote on May 21st, 2007, 1:49am:
Depending on signal input amplitude, some of the limiting amplifiers are slammed on, those are not contributing to usable singnal amplitude level information. Thus grabbing the information off of each stage. Did one of these things about 4 years back, probably still have the design buried someplace.
Jerry
aaron_do
Re: RSSI
Reply #4 - May 21st, 2007, 6:27pm
The way i want to add the AC signals together is quite simple. You have a differential amplifier, and instead of having only one input pair you divide it into several input pairs each one fed by one of the limiting amps. So you add the currents. In the actual design I combined the adder with the peak detector.
Also as for the point about phases i guess you are right. Actually I already took that into account. In my design, the phase shift from beginning to end is only 10 degrees which results in an error somewhere around 1-3%. Now that you mention it though, i had to force the limiter bandwidths to somewhere around 30 times the operating frequency which resulted in higher power consumption. So i guess maybe the standard way is better.
BTW Jerry, I don't understand your point about the limiters in limiting region not contributing to usable signal amplitude information. When you add the limiter outputs up, the limiting outputs contribute the largest part to the overall amplitude...
thanks everybody,
Aaron
RobertZ
the art of analog
San Diego, CA
Re: RSSI
Reply #5 - May 25th, 2007, 12:10pm
I did one RSSI before, not so great. But I used only one amplifier, one peak detection and some digital stuff.
Robert
