Nov 1st, 2024, 1:11am
Varactor-R LPF (Read 1194 times)
eng
USA
Varactor-R LPF
May 21st, 2007, 12:12pm
Attached figure shows a basic tunable integrator which will be used in a LPF with couple hundred kHz cutoff freq. The process supplies 2 port varactor devices so two back-to-back varactors are needed around OTA in order not to disturb DC op points while tuning. Then in this case node A is low impedance node which disturbs AC response. Does a 30k resistor between node A and Vtune fix that problem?
I need your comments on this kind of integrator with varactors? The bottlenecks & ways to improve it etc.
thanks
eng,
