Quote: The paper I was talking about is just the classic JSSC 1989 " Matching properties of MOS transistors" paper by Pelgrom. The take-home message was that mismatch standard deviation decreases with the square root of area.
Current factor mismatch can be tricky because strain can change it... .but most designs are more sensitive to Vt mismatches.
Oh, ok, I saw that paper many moons back, but truth be known, beyond a certain area, the matching does not improve significantly. Law of diminishing returns so to speak. Too much empirical data out there. If you have nothing else to go with, its a good first shot "educated guess approach" - As I am a reviewer for the JSSC, I don't take everything there as gospel, both good and (some) bad survive the review process and a lot of it becomes invalid for newer technology.
Current mismatch vs. threshold mismatch? I have always seen these as just two different ways of looking at the same thing. Hold the Vgates the same, look at the differenc in Idrain, -- or -- hold Idrains the same and look at the difference in Vgate.
