May 4th, 2024, 3:35pm
Alternate CAD tools for Analog/Custom IC Design (Read 5804 times)
SRF Tech
Arizona
May 26th, 2007, 12:53am
Hi everyone,
    I have been scouring the internet looking for viable low cost CAD tools.  Currently I am using Cadence, but am looking for a new low cost tool to use for custom analog and I/O design.
Most of my experience has been with Cadence, Mentor and Tanner.  I have also worked with several versions of freeware tools, such as LTSpice (which I like a lot) to name one, and a few layout tools to accompany it.  However what I need is a proper tool suite for some future projects on advanced processes (<90nm) that would make analog design, simulation, layout and validation a little easier to use than piecing together freeware.
I am leaning toward Tanner as my next tool of choice (cost mainly).
What I am looking for are any recommendations members of this forum may suggest as a tool choice to consider.  I know of many tools out there but I have no personal experience with some of them.  Maybe some of you know of a few off the wall tools that have served you well.
 I am open to suggestions.
Stephen
www.srftechnologies.com
mg777
Re: Alternate CAD tools for Analog/Custom IC Desig
Reply #1 - May 29th, 2007, 1:27am
Stephen,
Try the following link: http://www.vlsitechnology.org/html/ic_software.html
I suppose if you are designing specialized structures & have a deep knowledge of CMOS processing, you can 'dispense' with a PDK-based design flow. What about DRC, though? Maybe your designs go through a standard DRC downstream, so it may be OK to use 'non-standard' DRC tools?
M.G.Rajan
www.eecalc.com
SRF Tech
Arizona
Reply #2 - May 29th, 2007, 8:02am
MG,
 Thanks for the link.  There are a few tools here I have not heard of so it gives me some more research to do.
 Per your inquiry, it is important that I can still use base level verification flows such as DRC, LVS and some extraction.
 Yes, the designs do go thru a flow downstream, but customers do not like it when IP runs into DRC issues in their final assembly.  :(
 Anyway, I am still open to any other suggestions people may have for a quality tool.
Stephen
joel
Reply #3 - Jun 1st, 2007, 1:08pm
For years I was at a shop that used magic, along with Workview licenses that someone picked up at a garage sale or something.  We made a living with those tools.  I've heard that magic has been revitalized and can handle modern fancy processes.  Certainly worth a look.  I haven't tried it myself, but I'm interested in http://directory.fsf.org/electric.html .
Anyone know a freeware static-timing tool? And verilog?
I'm interested in what you find as well.  I'd like to have a set of tools for home use when between jobs.
SRF Tech
Arizona
Reply #4 - Jun 4th, 2007, 8:46am
Thanks for the pointing to this possibility Joel.  I will check it out and keep this message board posted on what I find.
Even Tanner does not offer a simulator capable of running Verilog/VHDL (that I am aware of).  So if I find something, I will let you know.
-Stephen
mg777
Reply #5 - Jun 4th, 2007, 11:09am
For a Verilog simulator: http://www.zeemz.com/products.php
(Note: I'm not affiliated with this company)
