Sep 29th, 2024, 10:20pm
how miminum length should I used? (Read 2065 times)
Robert
Xiamen city,Fujian PRO. china
May 31st, 2007, 3:03am
hi, all!
   i am designing a folded cascode OTA used in a LDO, to achive a acceptable offset caused by the transistor's mismatch, how miminum length of the input and load transistors should I used, my design is based on the Charter 0.35um CMOS process.  please give me any suggestions from your tapeout experience, thanks a lot!
best regards,
Robert
i am a gay,who loves ppmm!
krishnap
Re: how miminum length should I used?
Reply #1 - May 31st, 2007, 3:44am
Hi  Robert,
Usual practise is to keep minimum design length to be 2 to 3 times that of process node.
In this case 2-3*0.35um
Krishna
Berti
Reply #2 - Jun 4th, 2007, 12:20am
Hello Robert,
I think this depends on the offset you can tolerate.
For applications where offset isn't the major concern, but
speed is important I usually use minimum length transistors
to take full advantage of the technology.
If offset is important but speed moderate I agree with Krishna
not to use minimum design length.
Cheers,
Thomas
