Jul 16th, 2024, 8:33am
Cascode LVS seems to match but.. (Read 1996 times)
.matteo
Padova, Italy
Jun 4th, 2007, 2:27pm
hi all!
I'm trying to project a cascode amplifier. I finished the schematic and now I'm working on the layout (never done before, God save me please..)
here is my schematic:
http://www.thebags.it--out-of-date/listing/layout/01/schem.png
here is the entire layout I designed
http://www.thebags.it--out-of-date/listing/layout/01/layout_tutto.png
and some relevant particulars:
- M1 and IN1
http://www.thebags.it--out-of-date/listing/layout/01/M1.png
- connection between M1 and M0 and IN0
http://www.thebags.it--out-of-date/listing/layout/01/conn_m1_m0.png
- connection between M0 and the resistance connected to vdd
http://www.thebags.it--out-of-date/listing/layout/01/resistance_m0.png
(Do you think my layout should match the schematic? take a look to the pins ..I'm not sure they are ok)
1.: I run VRC and it sad only something about the density of my MET1 and POLY1 areas ..I didn't care ..hope I was right
2.:Then I extracted the circuit and run LVS ..LVS does not recongnise that I mad my MOS with 13 gates instead of one and give me some errors about it. Then there are some errors I'm not able to understand ..here it is:
Quote:
@(#)$CDS: LVS.exe version 5.1.0 07/02/2006 21:13 (cicln01) $
Command line: /nfsd/iccad/cds/ic5141b/tools/dfII/bin/32bit/LVS.exe -dir /home/bassimat/CAD/LVS -l -s -t /home/bassimat/CAD/LVS/layout /home/bassimat/CAD/LVS/schematic
Like matching is enabled.
Net swapping is enabled.
Using terminal names as correspondence points.
   Net-list summary for /home/bassimat/CAD/LVS/layout/netlist
      count
   6        nets
   5        terminals
   26        nmos4
   1        rpoly2
   Net-list summary for /home/bassimat/CAD/LVS/schematic/netlist
      count
   6        nets
   5        terminals
   2        nmos4
   1        rpoly2
   Terminal correspondence points
   N0        N2        IN0
   N4        N7        IN1
   N3        N6        OUT
   N2        N1        gnd!
   N1        N0        vdd!
Devices in the netlist but not in the rules:
       nmos4 pcapacitor rpoly2
   Ill-defined correspondence points.
   N0    N2  Accepted because one is a subset of the other
   N3    N6  Accepted because one is a subset of the other
   N4    N7  Accepted because one is a subset of the other
   N2    N1  Accepted because one is a subset of the other
   Device summary for layout
          bad  total
   nmos4        26     26
   Device summary for schematic
          bad  total
   nmos4         2      2
The net-lists failed to match.
                layout  schematic
               instances
   un-matched        26    2
   rewired            0    0
   size errors        0    0
   pruned            0    0
   active            27    3
   total            27    3
                 nets
   un-matched        1    1
   merged            0    0
   pruned            0    0
   active            6    6
   total            6    6
               terminals
   un-matched        0    0
   matched but
   different type        0    0
   total            5    5
Probe files from /home/bassimat/CAD/LVS/schematic
devbad.out:
I /MN1
? Device does not cross-match.
I /MN0
netbad.out:
N /net14
? Net does not cross-match. It has 2 connections.
mergenet.out:
termbad.out:
prunenet.out:
prunedev.out:
audit.out:
Probe files from /home/bassimat/CAD/LVS/layout
devbad.out:
The no. of lines exceeded than specified by the variable lvsLimitLinesInOutFile.
To see the complete information please see the file:
/home/bassimat/CAD/LVS/layout/devbad.out
netbad.out:
N /6
? Net does not cross-match. It has 26 connections.
mergenet.out:
termbad.out:
prunenet.out:
prunedev.out:
audit.out:
I run a simulation on the extracted circuit but the result is horrible ..it's another circuit Sad
can give me some suggestion about my layout? am I making some big mistakes?
thank you all!
matteo
« Last Edit: Sep 07th, 2011, 6:03pm by Forum Administrator »
