didac
There's a million ways to see the things in life
manresa,spain
Hi, I agree with mr.Wong, perform a backannotation at the schematic is very useful to see the effects at each node. I also agree with the fact that maybe R extraction rules are not always reliable(i've seen from different foundries strange behaviours). As I can see in the attached file the layout is apparently symmetric, one thing that you can check is the number of vias used,i.e. in one track you put 2 vias to make a change and in the symmetric one you only put one(I incurred in this error too and then starts the long debuggin hours) so the equivalent resistance(not shown in parasitics) is bigger. Good luck,keep in touch
