Sep 27th, 2024, 10:17pm
Peak to average Power (Read 957 times)
Nibblo
Jun 06th, 2007, 7:16am
I would like to know how the peak to average power is
calculated using Cadence Spectre tools. This for a modulated signal
measured at the output. I believe a simple measure of Vrms*Irms is
not sufficient. This because the signal is a modulated signal.
A few detailed steps using the cadence calculator
would be appreciated.
chase.ng
penang/malaysia
Re: Peak to average Power
Reply #1 - Jun 7th, 2007, 8:47pm
Peak to average power is a ratio commonly known as PAPR, definately is not Vrms*Irms. If the load is constant, then Vrms^2/R will give the average power. To calculate the peak power, use Vpeak^2/(2*R).
regards,
chase
Chase
View Profile chase.ng   IP Logged
Nibblo
Reply #2 - Jun 8th, 2007, 3:32am
The two equations you specify are the same mathematically Smiley
RFICDUDE
Reply #3 - Jun 9th, 2007, 5:23am
For a single sinusoid the two equations are the same. This is why a CW signal is said to have a PAPR = 1 or 0 dB.
In general amplitude modulated signal have a PAPR > 0 dB, so you need to measure Vrms and Vpk as indicated in the expression (so long as you are measuring it across a load resistor R).
chase.ng
penang/malaysia
Reply #4 - Jun 12th, 2007, 10:17pm
Hi RFICDUDE,
Thanks for clarifying that, guess I didn't make it clear enough at the first place.   Smiley
chase
Chase
