Jul 17th, 2024, 10:35pm
lost Events in asynchr. comparator w AMS/spectre (Read 6081 times)
boe
Jun 07th, 2007, 7:34am
I wrote an asynchr. comparator similar to the one in http://www.designers-guide.org/Books/dg-vams/ch4/listing14.tar.gz; Code fragment:
 logic CompOut;
 electrical VCompIn;
 parameter real Vhyst = 3.75e-3;
 parameter real tpd = 25e-9;
 always @(cross(VCompIn - Vhyst/2, +1, 1n, Vhyst/10.0))
     CompOut  <= #(tpd/1n) 1;
 always @(cross(VCompIn + Vhyst/2, -1, 1n, Vhyst/10.0))
     CompOut <= #(tpd/1n) 0;
I ran this with ncsim (AMS/spectre). The problem I have is that I loose events. First I get the warning
> Warning from spectre at time = 34.7478 ms during transient analysis `tran'.
>     Analog events may be missing and simulation results may not be correct
>         since time step was too big to catch the details in device/AHDL models.
>         Use bound_step() or tighten simulation tolerance options to limit the
>         time step.
At 70.2917608ms I clearly see a missing event which is not passed on to the digital simulator.
The signal VCompIn goes to -1 V and remains there for ca. 8 us, but CompOut remains at "1" all the time!
I can see no reason for the simulator not to catch the event - is my code poor or is this a simulator bug?
Re: lost Events in asynchr. comparator w AMS/spect
Reply #1 - Jun 7th, 2007, 10:25am
Boe,
    Your model looks good to me. I can see no reason why the simulator should skip the event. It is very odd that the simulator recognizes that it is missing the event and admits it rather than just handling the event properly. The suggestion to use bound_step() (or equivalently the maxstep transient analysis parameter) might be a work around to the problem, but this seems like a simulator problem that really should be fixed by Cadence. I suggest you bundle up an example and send it off to them so they can fix it.
boe
Reply #2 - Jun 7th, 2007, 11:10am
Ken Kundert wrote on Jun 7th, 2007, 10:25am:
Boe,
Ken,
First of all: Thanks you very much for your advice.
The suggestion to use bound_step() does not help very much though, because I do not know how to do a better prediction of critical transitions efficiently with less information than the simulator: The comparator is asynchronuous and switches very often -- and only very few transitions cause problems...
BOE
Reply #3 - Jun 12th, 2007, 5:49am
Boe,
  You did not mention the simulation conditions you used. Sometimes tightening
the simulation conditions help to resolve these types of issues. For example, using
the moderate error preset with relref=pointlocal.
boe
Reply #4 - Jun 12th, 2007, 8:20am
Sheldon,
I used the following parameters:
   reltol = 10e-06
   abstol(I) = 100 fA
   abstol(V) = 1 uV
   errpreset = conservative
   method = gear2only
   relref = alllocal
BOE
boe
Reply #5 - Jul 3rd, 2007, 7:38am
Lasr week, we got an answer from Cadence: the problem does no longer show up in versions IUS 5.70.s016/IUS 5.83.s006.
I attach the input of the "cross" of the testcase we sent to Cadence, run with IUS 5.70.s012 (red) and with IUS 5.70.s017 (blue): The critical time is 1.9637556 ms to 1.963756 ms. The s012 uses only 1 step in this range; thus, the s012 has no time step in the tolerance band of the cross event. This seems to be the reason that the event is lost.
Apparently, Cadence changed the simulator time step control between s012 and s016, so that the problem does no longer occur.
BOE
