Aug 15th, 2024, 7:30pm
pnoise result is different from noise sim (Read 2112 times)
waynechen
Jun 10th, 2007, 11:11pm
I have used noise sim for a while and just start to use pnoise.  I tried on a simple RC with vsin source (they are all series) and measure the noise across capacitor.  The result are all different.  The following is the testbench simulation condition and result.  My question is noise sim result is different from pnoise sim at low freq noise (for ex. at 10Hz).  When freq_vsin>>freq_rc, ponise_timedomain is close to noise sim.  When freq_vsin<<freq_rc, ponise_source is close to  noise sim.  Can any expert explain to me this question.
Thank you very much
BR,
Wayne
R1=5kOhms
C1=1, 10000pF
Vsin=1MHz, amp=1v
* Noise sim
- sweep freq=1~100MHz
* PSS sim
- num. of harmonics=10
*pnoise sim
- realtive harmonic=1
- max. sideband=15
- noise type= source / timedomain
result at low freq noise (V2/Hz)
             noise_sim     pnoise_source   pnoise_timedomain
c1=10nf   83e-18           83e-23            83e-18
c1=1pf     83e-18           83e-18            2.3e-15
graham
Re: pnoise result is different from noise sim
Reply #1 - Jun 20th, 2007, 6:18am
Hi Wayne
I think what you are doing, by using "relative harmonic=1" is looking at the noise at 10Hz away from the Vsin of 1MHz. This is then giving a correct value for pnoise_source of 83e-23 - the resistor noise is, of course, shunted by the capacitor. The noise is (in 1Hz band)
(4.k.T.R)/(1+(2.Pi.F.R.C)^2) with F= 1e6
I don't know about pnoise_timedomain. I suggest looking it up somewhere. It is not easy to understand from looking at the screen options.
regards
Graham
