Jul 21st, 2024, 2:16pm
Question about bisim3v3 parameters (Read 5655 times)
kiran123
Jun 11th, 2007, 1:19am
Hi
  i am using BISIM3v3 level -11 model parameters and i could not find  parameter "phi"  which is useful for below equation ,
VTH = VT0 + gamma * ( sqrt(phi - VBS)  - sqrt(phi) )
can anyone help me on how to get this
gamma is declared as k1 in models statement
Thanks & Regards
Kiran
Re: Question about bisim3v3 parameters
Reply #1 - Jun 11th, 2007, 4:12am
The Berkeley code for BSIM3 has:
                 pParam->BSIM3phi = 2.0 * Vtm0
                                  * log(pParam->BSIM3npeak / ni);
where Vtm0 is kT/q (for T=tnom) and BSIM3npeak is entered as the parameter NCH.  ni is the intrinsic carrier concentration of Si.
kiran123
Reply #2 - Jun 12th, 2007, 12:50am
Geoffrey_Coram wrote on Jun 11th, 2007, 4:12am:
Geoffrey,
        what is this "pParam->" declaration ? where should i mention this to get "phi" value ?
i understood that the above equation is looks like
         "phi"    =  2 * kt/q  * log( ni / NA)
can i take kT/q = 26mV at 300k
        &    ni    =   1.45* 10^10 cm^-2  otherwise where from i should get ?
              NA   = nsub or nch  ?
Kiran
Reply #3 - Jun 12th, 2007, 4:14am
kiran123 wrote on Jun 12th, 2007, 12:50am:
              NA   = nsub or nch  ?
pParam is a data structure in the BSIM3 source code (having to do with sharing values for devices with the same L and W).
You inverted the division in the log, it's log(NCH/ni), and NCH is the parameter.
ni = 1.45e10 * (Tnom / 300.15) * sqrt(Tnom / 300.15) * exp(21.5565981 - Eg0 / (2.0 * Vtm0));
You should double-check that Tnom in the model card is 27.0 C (which would be 300.15 K), else you'll have to adjust ni and kT/q from what you are using; then again, you may not care to be all that exact.
kiran123
Reply #4 - Jun 21st, 2007, 12:05am
Geoffrey_Coram wrote on Jun 12th, 2007, 4:14am:
              NA   = nsub or nch  ?
Geoffrey,
  Thanks a lot for  sharing helpful information on this , if possible can you tell me why should NCH is to be consider instead of nsub, some text boox says it is nsub i.e equivalent SPICE parametr name is NSUB
from the model file information i found below definition for them
NCH: Peak Channel doping concentration
Nsub : substrate doping concentration
thanks
Kiran
Reply #5 - Jun 21st, 2007, 10:18am
Have you tried reading the appropriate section of the BSIM3 manual?  I assume it's explained there.
