Menas
Hello Everybody,
I'm using ADvance-MS from Mentor Graphics.
I have to model an Impedance which varies with the frequency. So I have created some functions to enable it (Bessel functions...etc...). This is OK while a consider this impedance as a purely resistive impedance (ie. a real). But the point is that this impedance is in fact an Imaginary. So I tried to use the package MATH_COMPLEX, but the problem is that a QUANTITY must be real, so it's impossible to use complex numbers in simultaneous statements. I also tried things like i==Z*u'dot, but I'd like to see the impedance value as the Real part/imaginary part (ADVANCE MS allows it) I have modelled a Ohmmetre in order to measure the U/I ratio, but it doesn't work, even if the impedance is real...(the ration is always equal to zero) Should I use the FFT function provided in EZ Wave?
My question is : "How to measure a complex impedance in a AC analysis ?" Can Someone help me ?
