Sep 28th, 2026, 6:22am
How to realize Buffer with inertial delay in V-AMS (Read 2092 times)
seefree
Jun 11th, 2007, 12:26pm
I want to write a digital buffer with inertial delay in Verilog-AMS. The digital output is the same as input with delay time "t_delay" except the input pulse time "t_inertial" smaller than half of "t_delay".
For example, the buffer has tow parameters, t_delay and t_inertial = [0:t_delay]. If the digital input pulse time (no matter up/down) is bigger than t_inertial, the output is the input with delay t_delay. Otherwise, the output is unchanged.
Does Verilog-AMS have the similar system function to realize it?
Thanks a lot,
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: How to realize Buffer with inertial delay in V
Reply #1 - Jul 23rd, 2007, 4:48am
The transition function should do well.
